铁甲网首页 铁甲论坛 德国钻车新秀 BBURG DH700/900 - DF700S
绝对音感 2012-01-19
7473 12
type      HD 700                                          HD 900
drill type  top hammer / drifter
hole diameter   64 - 100 mm                         76 - 115 mm
hole diameter   2,5" - 4"                               3" - 4,5"
drill rod type   T38 / T45                               T45 / T 51
drifter performance  22 kW                           30 kW
rotation torque   1040 Nm                            1400 - 1650 Nm
rotation speed / rpm  50 - 180                      50 - 120
drill rod length   3660 mm                             4265 mm
number of rods / tubes  7 + 1                       7 + 1
drill depth           28 m                                  33 m
drill depth indicator digital  standard
drill angle indicator 2 - D  option
drill angle indicator 3 - D  option
feed length    7180 mm    7820 mm
feed tilt left / right  12° - 90° or 90° - 12° changable by reloca-tion of boom swing cylinder
arm type  two piece
engine manufacturer  DEUTZ / CAT                DEUTZ / CAT
engine type    TCD 2013 / C7                        TCD 2013 / C 7
engine power in kW  175 / 168                      190 / 186
engine rpm    2100                                       2000
emission rating  TIR 3, option TIR 4
compressor type  rotary screw, single stage
air delivery / minute
                    8 m3 / 280 cfm                        11 m3 / 390 cfm
air pressure in bar / psi
                     12 / 175                                 12 / 175
dust absorber
HD precleaner   yes                                        yes
main cleaner no of filters
                      11                                          11
total surface filters in m2
                      17                                          17
Undercarriage  B 2
number of speeds   2                                       2
travel speed   0 - 4,5 km/h                              0 - 4,5 km/h
shoe type  triple grouser / option single grouser
shoe width    300 mm
ground clearance  425 mm                              425 mm
max. gradebility  30°     30°
max. track oszillation  12°                              12°
hydraulic tank volume  300 l                            300 l
diesel reservoir   410 l                                     410 l
weight in kg   15.000                                      16.800
dimensions (L x W x H) in mm
     9600 x 2495 x 3200                                10800 x 2495 x 3200
 该贴已经同步到 绝对音感的微博
