铁甲网首页 铁甲论坛 锤破制砂机供应厂家锤破制砂机锤破破碎机
锤破制砂机供应厂家锤破制砂机锤破破碎机
挖机非也非也1877 2025-03-16
933 0
锤破制砂机供应厂家锤破制砂机锤破破碎机
锤式破碎机的保养方法有哪些
1、定期检查机器内部部件的磨损情况要定期检查机器内部部件的磨损情况,如中心入料管、锥帽、叶轮上、下流道衬板、圆周护板、鄂板的磨损程度,磨损较严重的要及时进行修补或更换,同时更换部件的重量、型号和尺寸等,一定都要按原来的部件参数进行更换。
2、做好润滑工作要经常注意并及时做好摩擦面的润滑工作,且所采用的润滑脂应根据使用的地点、气温条件而定,一般情况下采用钙基、钠基和钙钠基润滑脂;加入润滑脂时应先用洁净的或煤油清洗滚柱轴承的滚道,然后再加入,加入轴承座内的润滑脂应为其空间容积的50%左右,锤破制砂机生产厂家,而且每3~6个月更换一次,这样既确保了机器的正常运转又延长了使用寿命。
3、保持设备的清洁要经常保持设备的清洁,做到无积灰、无油污、不漏油、不漏水、不漏电、不漏灰,更要注意灰尘等杂物不得进入润滑系统和润滑部位,锤破制砂机现货销售,因为这些杂物不仅会破坏润滑油膜,而且会使设备失去润滑而增加磨损,缩短设备的使用寿命;尤其要注意对轴承的定期清洗,破碎机在作2000小时后,打开主轴总成对轴承进行清洗,一般工作7200小时后要更换新轴承。
联系人:李先生13938473005
What are the maintenance methods for hammer crushers
1. Regularly inspect the wear of internal components of the machine, such as the wear degree of the central feeding tube, cone cap, impeller upper and lower channel lining plates, circumferential guard plates, and jaw plates. Those with severe wear should be repaired or replaced in a timely manner. At the same time, the weight, model, and size of the replaced components must be replaced according to the original component parameters.
2. Regular attention should be paid to and timely lubrication of the friction surface when performing lubrication work, and the lubricating grease used should be determined according to the location of use and temperature conditions. Generally, calcium based, sodium based, and calcium sodium based lubricating greases are used; When adding lubricating grease, the raceway of the roller bearing should be cleaned with clean or kerosene first, and then added. The lubricating grease added to the bearing seat should be about 50% of its spatial volume. The manufacturer of the hammer sand making machine should replace it every 3-6 months, which ensures the normal operation of the machine and extends its service life.
3. To keep the equipment clean, it is necessary to regularly maintain its cleanliness, ensuring that there is no accumulation of dust, oil, oil, water, electricity, or dust. It is also important to note that dust and other debris should not enter the lubrication system and lubrication parts. Hammer sand making machines are sold in stock because these debris not only damage the lubricating oil film, but also cause the equipment to lose lubrication and increase wear, shortening its service life; Special attention should be paid to regular cleaning of bearings. After 2000 hours of operation, the crusher should open the main shaft assembly to clean the bearings. Generally, new bearings should be replaced after 7200 hours of operation.
