铁甲网首页 铁甲论坛 泰安现代重工XDCY-1A 1.0立方内燃铲运机
泰安装载机 2020-11-26
2272 0
●动力系统采用4105增压发动机,功率大,排放低。
●采用技术领先的回转支承结构,液压转向,相比传统的后桥摆动形式,故障率更低。
●行走系统采用280型液力变矩器、20型动力换档变速箱,加重型轮边减速桥,维护方便,配套件更易采购。
●工作系统采用先导操控,使操作更加简单,工作效率更高。
●采用液压转向,双转向油缸,转向更平稳。
●驻车制动为弹簧制动、液压释放,并配备紧急制动系统,使制动安全可靠。
●尾气排放采用水过滤系统,并可选装进口三元催化器,大大降低了空气污染。
●整车机架钢板加厚,钢性增强,铲斗主板采用耐磨400特钢钢板,经久耐用,使用寿命更长。
●采用9.75-18光面耐磨防穿刺橡胶轮胎。
●整机长度≤5.7米,整机宽度≤1.3米,整机高度≤2.0米。
●选装湿式制动桥。
●整机宽度1.3米,该机结构紧凑,转弯半径小,可进行铲、装、运、卸一体作业,操作方便,作业效率高。适合回采出矿和巷道掘进出碴,以及工作场地和道路的修筑平整,材料运输等辅助作业。
Features & Benefits
1. Power system adopts China’s top brand YTO engine or China made CUMMINS/DEUTZ engine with low speed and high torque.
2. Tranission system uses mining customized hydraulic torque converter and power shift gearbox to ensure its stability and high efficiency.
3. Operating system adopts pilot control to make operation easily and work efficiently.
4. Service brake adopts air over hydraulic oil caliper brake technology, parking brake uses spring brake, hydraulic release, and is equipped with an emergency braking system, to guarantee its safety and reliability.
5. Exhaust cleaning system is equipped with diesel oxidation catalyst (DOC) and water filtration system, greatly reducing air pollution.
6. 9.75-18 ooth, wear-resistant and puncture- resistant tires for long working life.
7. Technology leader slewing structure, hydraulic steering, lower failure rate, easy to maintain.
8. The loader has compact structure and all turning radius. It can be used for shoveling, loading, transporting and unloading. It is easy to be operated and has high working efficiency. Suitable for mining and roadway excavating, as well as road construction and material transportation.
