铁甲网首页 铁甲论坛 泰安闲的重工XD918 1.6吨井下装载机
泰安装载机 2020-11-28
2471 0
主要性能特点
●4102或4102增压发动机,280型双变。
●工程机械专用轮边减速桥,气推油钳盘式制动。
●低型:整机宽度≤1.6米,整机高度≤1.9米(到简易棚尺寸),整机长度≤5.11米。
高型:整机宽度≤1.6米,整机高度≤2.3米(到简易棚尺寸),整机长度≤4.72米。
●更窄、更矮、更短,适应超低、超窄巷道。
●标配12-16.5轮胎,选装9.75-18轮胎。
●铲斗刃板采用耐磨400特钢钢板。
●铲斗宽度可根据用户需求定做。
●标配废气水过滤装置。
●选装进口三元催化器。
●选装侧卸装置。
●选装轮胎保护链。
1. Power system adopts China’s top brand YUNNEI engine with low speed and high torque.
2. Transission system uses mining customized hydraulic torque converter and power shift gearbox to ensure its stability and high efficiency.
3. Service brake adopts air over hydraulic oil caliper brake technology.
4. Exhaust cleaning system is equipped with Diesel oxidation catalyst (DOC) and water filtration system, greatly reducing air pollution.
5. The loader has compact structure and sall turning radius. It can be used for shoveling, loading, transporting and unloading. It is easy to be operated and has high working efficiency. Suitable for mining and roadway excavating, as well as road construction and material transportation.
