铁甲网首页 铁甲论坛 泰安现代重工XDCY-2 2.0立方内燃铲运机
泰安装载机 2020-11-26
1728 0
产品详细介绍
●动力系统采用东方红4110增压发动机,储备扭矩大,动力强劲,皮实耐造;故障率低,维修简单,适应井下高温、潮湿等恶劣工况。
●传动系统采用山推液力变矩器+动力换挡变速箱,前进四档,后退二档,变速范围大,并匹配大速比矿山机械轮边减速桥,实现低速大扭矩,使一档铲装更有力,铲斗易于装满,作业效率高。
●行走系统采用液力变矩器、动力换档变速箱,提高了可靠性。
●工作系统采用先导操控,使工作操作更加简单,工作效率更高。
●电气系统经过防水防潮设计,适应井下潮湿工况。
●发动机进气系统采用油浴式空气滤清器,取代普通的纸质空气过滤器(纸质滤芯会因进气潮湿而变形堵塞,失去过滤效果),无需更换滤芯。
●尾气净化系统采用水过滤装置+氧化催化器,实现双级过滤,尾气以水雾的型式排出并快速沉降到地面,大大降低空气污染,保护巷道环境及驾驶员身心健康。
●行车制动为多盘湿式制动,驻车制动为弹簧制动、液压释放,使制动安全可靠。
●整车机架钢板加厚,整车钢性增强,铲斗铲刃采用高强度合金钢制造,耐磨抗剪切, V型结构,减小了铲取阻力,使用寿命更长。
●采用耐磨防穿刺光面橡胶轮胎,使用寿命长。
●爬坡能力强,满载最大爬坡16°,在卷扬机辅助下,可用于25°以内斜坡道打掘进,替代扒渣机。
●该机后车架可拆成5部分,便于下井。
●该机结构紧凑,操作方便,可进行铲、装、运、卸一体作业,工作效率高,适合回采出矿和巷道掘进出碴,以及工作场地和道路的修筑平整、材料运输等辅助作业。
1. Power system adopts China’s top brand YTO turbocharged engine or China made CUMMINS engine with low speed and high torque.
2. Tranission system uses mining customized hydraulic torque converter and power shift gearbox SHANTUI brand to ensure its stability and high efficiency.
3. Operating system adopts pilot control to make operation easily and work efficiently.
4. Service brake adopts multi-disc wet brake technology, parking brake uses spring brake, hydraulic release, and is equipped with an emergency braking system, to guarantee its safety and reliability.
5. Exhaust cleaning system is equipped with Diesel Oxidation Catalyst (DOC) and water filtration system, greatly reducing air pollution.
6. 12.00-24 ooth, wear-resistant and puncture- resistant tires for long working life.
7. Technology leader slewing structure, hydraulic steering, lower failure rate, easy to maintain.
8. The loader has compact structure and all turning radius. It can be used for shoveling , loading, transporting and unloading. It is easy to be operated and has high working efficiency. Suitable for mining and roadway excavating, as well as road construction and material transportation.
